I bought a bearing, seal, and wrench from you. I want to remove the bin from the washer to replace the washer. I have removed the tub completely from the washer, and have removed the left hand threaded nut with the wrench and hammer. Everything I see says now just lift out the inner basket. It seems that is not the case, it doesnt budge at all. Is there another nut or something I need to do to remove the basket after I removed the big left hand nut ?
Originally Posted by: stevenleeeaton I bought a bearing, seal, and wrench from you. I want to remove the bin from the washer to replace the washer. I have removed the tub completely from the washer, and have removed the left hand threaded nut with the wrench and hammer. Everything I see says now just lift out the inner basket. It seems that is not the case, it doesnt budge at all. Is there another nut or something I need to do to remove the basket after I removed the big left hand nut ? Never mind. I soaked the thing for hours in wd40. Still no go. I pounded on the hub time and time again from multiple sides. it came right out
I usually leave the spin basket nut on half way and pound directly on the nut, protects the threads.
