acarpenter33
#1 Posted : Saturday, April 9, 2011 11:31:59 AM(UTC)
acarpenter33
All of a sudden the washer in spin cycle stopped letting the water drain out. Took the pipeing under the washer that goes to the pump off, cleaned it, nothing is blocking the water from draining. Put back together, still doing the same thing. I took the vacuum off and when I suck on it, it holds pressure so could it be either the lid switch or drain pump.
bevil45181
#2 Posted : Saturday, April 9, 2011 1:43:27 PM(UTC)
bevil45181
If you advance the timer to spin and press start do you hear the pump motor attempting to spin? Also, if you move the timer to wash/fill cycle will the washer begin to fill and lock the door? If you are confortable working with electric I recommend making a patch cord and sending power directly to the pump motor to see if it will begin pumping. Check these out, then repost.
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 11:05:27 PM(UTC)
maytag washer will not drain water (Washer Repair)
by mathy10544 12/13/2015 11:54:09 PM(UTC)
GE front load washer will not drain (Washer Repair)
by Sandmann01 6/22/2015 4:24:04 AM(UTC)
Washer will not drain (Washer Repair)
by Artnlp 5/3/2015 10:34:59 AM(UTC)
Washer will not drain in Normal cycle (Washer Repair)
by rober luck 4/20/2015 12:10:47 PM(UTC)
by charles140 10/10/2014 11:21:01 AM(UTC)
by hurler72 11/25/2013 1:59:35 PM(UTC)
topload washer will not drain or spin (Washer Repair)
by olac757@gmail.com 8/10/2013 12:08:21 AM(UTC)
Whirlpool dishwasher will not drain (Dishwasher Repair)
by PeterZ 8/6/2013 10:21:51 PM(UTC)
Washer will not drain or spin (Washer Repair)
by Fixit Dad 5/23/2013 7:26:49 PM(UTC)
by PepperVal 5/16/2013 11:36:29 AM(UTC)
Whirlpool Washer will not drain unless open and close lid (Washer Repair)
by twhistle 2/28/2013 11:16:58 AM(UTC)
Washer will not drain or spin, new pump and lid switch (Washer Repair)
by tangerine30680 1/26/2013 3:42:38 PM(UTC)
I replaced lid switch, still washer will not drain or spin (Washer Repair)
by dnschrstn 11/12/2012 3:39:16 PM(UTC)
washer will not drain before the spin cycle (Washer Repair)
by tondot 11/11/2012 8:32:56 PM(UTC)
