Hi there, I 'm trying installed part number WPL 1200213 (thrust bearing kits) and can't see getting to work. I already taking all old ones out, but I could not put the new ones in because the pulley that has extra appoximate 1" longer. How can I do. Thank a lot.
Edward
You have to pull down on the shaft to get enough to put the pieces back on. Sometimes it is pretty hard, and a helper is usually, well, a lot of help.
