4tmike
#1 Posted : Tuesday, March 29, 2011 7:51:32 PM(UTC)
4tmike
goes into spin mode when helix push's up on drive pulley agaist clutch fingers begins to spin then the helix just rides up and down the the pulley.
what keeps the helix and drive pulley connected spin mode. pressure from clutch?do i need a new clutch?
sidfink43
#2 Posted : Thursday, March 31, 2011 3:50:36 PM(UTC)
sidfink43
Here is the explanation of what is happening from the service manual.
The drive pulley turns clockwise riding up the ramps of
the helix, exerting pressure on the brake and forcing it to
release from brake pads. The helix drives the input shaft
of the transmission, and when the input shaft turns in a
clockwise direction the roller clutch locks onto the shaft
causing the entire transmission assembly to turn. None
of the gears in the transmission are operating at this
time. The hub of the washtub is attached to the
transmission tube and rotates with the transmission
assembly. The centrifugal force created by the spinning
washtub causes water to be extracted from the clothes.
Sounds like the helix is not operating properly and allowing the brakes to release.
4tmike
#3 Posted : Thursday, March 31, 2011 5:55:29 PM(UTC)
4tmike
in a counterclock rotation the belt pulley goes up the helix and releases the the brakes but doesn't stay on top of helix but drops down the to the bttom and runs up and over the helix again . what is supposed to keep the helix and the pulley together once the pulley releases the brake to spin the tub. is the pressure from the brake fingers to keep the helix and pulley coupled
sidfink43
#4 Posted : Friday, April 1, 2011 4:43:43 AM(UTC)
sidfink43
The rotation should accomplish it.
4tmike
#5 Posted : Friday, April 1, 2011 5:44:06 PM(UTC)
4tmike
replaced helix and pulley seems to work fine now.there was stong 1/16 inch groove in pulley where it contacts helix.:D
sidfink43
#6 Posted : Friday, April 1, 2011 5:55:20 PM(UTC)
sidfink43
Great, glad you found the problem and thanks for the update.
4tmike
#7 Posted : Friday, April 1, 2011 7:43:29 PM(UTC)
4tmike
not as good as i thought. motor smelling hot thermal breaker kiicked.
water all over floor appears to have come from over top of tub.
turn belt in spin direction brake off spins freely wash direction seems to work also.now what?:confused:
sidfink43
#8 Posted : Saturday, April 2, 2011 3:24:00 PM(UTC)
sidfink43
Well you may have inadvertently disconnected the tube on the tub that goes to the water level switch, so check that.
Are you saying your motor thermal protection kicked in? If so, run the machine with the front off and see if you can tell what is going on.
4tmike
#9 Posted : Saturday, April 2, 2011 4:22:24 PM(UTC)
4tmike
yes motor thermal kicked in
motor is working hard in the spin cycle with a load in it.maybe the brake is not totally releasing?ck'd pressure switch looks connected to tub will ck in panel.seems to spin ok without load.did find belt idler pulley off fixed that.
water was coming out over top of tub in spin cycle .in spin cycle the trans.is locked it just staight through?thinking brake clutch maybe the problem.
Kenmore Washer Hums and Won't spin (Washer Repair)
by dieselgg 5/18/2024 6:29:18 AM(UTC)
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
Samsung dryer won't spin (Dryer Repair)
by Guest 8/13/2023 2:50:03 PM(UTC)
Samsung washer won't spin (Washer Repair)
by Guest 1/8/2022 10:56:39 AM(UTC)
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Machine goes through cycle but won't spin (Washer Repair)
by Guest 9/12/2021 10:04:44 AM(UTC)
Whirlpool cabrio won't spin out (Washer Repair)
by Guest 7/28/2021 7:22:56 AM(UTC)
Pumps but won't spin or drain (Washer Repair)
by Guest 6/21/2021 2:45:48 PM(UTC)
SQ Washer Tub Won't Spin Still After Initial Troubleshooting (Dishwasher Repair)
by vamazzeo 4/16/2021 10:00:33 AM(UTC)
Whirlpool Ultimate Care II LSQ8243HQ0 won't spin (Washer Repair)
by williamlee 4/7/2021 4:58:55 PM(UTC)
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4/7/2021 8:42:00 AM(UTC)
GE Top Load washing machine, won't spin & won't stop cycling (Washer Repair)
by Stefano31 9/29/2020 3:01:44 PM(UTC)
DV448AEP/XAA Dryer Won't Spin (Dryer Repair)
by hufe1983 1/13/2020 4:48:55 PM(UTC)
Won't spin fast - only slow (Washer Repair)
by Machine_Slo 1/6/2020 9:16:58 PM(UTC)
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
