dryer heats up with no load in it. when i put in a load the heat shuts off and it keep on tumbling and never dries. i cleaned the exhust duct all the way out of the house, is this senser or regulator or what?
Hello. Check the coils and see if they test good. You can test the coils using a multi-meter. The two prong coil will read 1,000-1,300 ohms, and the three prong coil will read 1,300-1,400 ohms across prongs 1&2, and 500-600 ohms across prongs 1&3. Let the dryer run for a few minutes and then check them. Hope this helps. Part number: AP3094251
