The convection fan on my Jenn Air JDS9860AAW does not come on at all. There are no error codes and the little fan on the display shows it working. Some things I checked: The oven lock does work on clean mode I pulled the fan and checked it. It works on hi and low The downdraft fan is not hooked up if that matters. Is there a way to check the board? The cooling fan runs ok and everything else works. Thanks in advance for any help Nelson
