The Insinkerator Badger 1 had a small spoon go in it. The head of the spoon was removed but the handle is jammed inside. The z tool can't turn the insides at all. Any suggestions ?:o I took the unit apart and removed the rest of the spoon.The reassemble instruction that says to " hang disposer by aligning 3 mounting tabs w/slide up ramps on mounting ring" does/nt seem to go together as easy as they make it sound. Any suggestions?
