tdma
#1 Posted : Saturday, March 19, 2011 4:28:41 PM(UTC)
tdma
washer stops at rinse cycle. I was able to remove the clothing and turn the knob to reset and it spun and drained the washer. I thought it was just a overload issue.
The next load. very light, did the same thing, I turned the load size knob
from large to medium and then turned to reset again and it finished the load again.
Why does it keep stopping at the rinse cycle with the washer full of water?
Thanks,
Gerry
tdma
#2 Posted : Saturday, March 19, 2011 5:57:20 PM(UTC)
tdma
I may have the answer to my own question.
After reading the manual it says the machine must be level. It appears to be tilted a bit with the front down. I wonder if this is causing it to shut down when heavily loaded?
In the morning I will get out a level and some wrenches.
Do any of you pro's have any input on this?
Gerry
tdma
#3 Posted : Sunday, March 20, 2011 7:30:57 AM(UTC)
tdma
I balanced the washer and am running a light load as we speak.
Wife seems to think the whole process is taking to long for a load.
Can anyone point me to info on how long each cycle should run?
I am not in the mood to changed a 133dollar timer for no reason.
tdma
#4 Posted : Sunday, March 20, 2011 8:03:05 AM(UTC)
tdma
balancing the machine did not fix the problem.
load seems to stop mid cycle. the timer does advance but seems to be very slow. I had to manualy advance the timer to get the load finished, then they where not clean, I believe i advanced it past the wash cycle just to get the machine to empty.
When i manually advanced it to spin it seemed to operate normally.
Is my timer shot?
Cant remove metal tub old Whirlpool/ Kitchen Aide Washer Please Help! (Washer Repair)
by robertgarven 3/23/2018 2:24:04 PM(UTC)
kitchen aide dishwasher will not start (Dishwasher Repair)
by Edwin L Davis 4/26/2015 6:02:45 PM(UTC)
Kitchen Aide Supurba Oven (Oven Repair (including Ranges and Cooktops))
by mcmordo 12/30/2011 5:56:48 AM(UTC)
Kitchen Aide Range left front burner failure and electronic odor (Oven Repair (including Ranges and Cooktops))
by sonset 12/12/2011 4:22:53 PM(UTC)
Kitchen Aide Dishwasher stopped running (Dishwasher Repair)
by jdgriffith 6/21/2011 3:32:27 PM(UTC)
kitchen aide dryer not turning on (Dryer Repair)
by dakota70 7/13/2010 12:23:39 PM(UTC)
Kitchen Aide Side by Side Freezer cold Refrigerator warm (Refrigerator & Freezer Repair)
by vbarajas 3/23/2010 10:05:38 AM(UTC)
kitchen aide electric dryer tripping breaker (Dryer Repair)
by mitsujoe 2/25/2010 3:08:02 PM(UTC)
kitchen aide washer (Washer Repair)
by waki175 12/8/2009 10:51:34 AM(UTC)
kitchen aide elec oven takes longer to bake (Oven Repair (including Ranges and Cooktops))
by rickharp 12/1/2009 3:59:49 AM(UTC)
Kitchen Aide dishwasher with power but won't cycle. (Dishwasher Repair)
by bridfamily 4/3/2009 9:27:23 AM(UTC)
