rterrass
#1 Posted : Thursday, March 17, 2011 1:54:24 PM(UTC)
rterrass
The right front dual element on my Jenn Air series 10 range only operates at high no matter what heat is selected. I suspect it is the limiter #74002667 which is no longer available and no substitute that is recommended. Is there a way to replace the dual element 74002666 and separate limiter with a newer element with the limiter included or some other part source that will solve my problem?
Thanks for any help.
#2 Posted : Friday, March 18, 2011 1:40:25 AM(UTC)
Not sure why you feel it is the limiter.
I would lean more towards the infinite (control) switch.
The limiter just protects the stovetop from an overheating problem.
So it is normally closed and opens if it senses overheating which shuts the element off.
