The door glass in the range got shatter when moving. I have the replacement glass and trim kit. When trying to put it back on, the side trim does not seem to fit. The side trim parts are the newer version with built in pegs rather than the screw in type. Any ideas on how to get the side trim strips installed ? Thanks in advance
