Rick P
#1 Posted : Thursday, October 18, 2007 2:53:26 AM(UTC)
Rick P
I Replaced The Door Latch Assy. The Old One Had 2 Micro Switches Mounted On Each Side Of The Center Of The Assy. The Black Wires Were Connected To The Switch On The Right And The White On The Left. The New Latch Assy Was A Slightly Different Design With 4 Contacts Coming Out Of A Enclosed Column. I Connected The Black Wires To The 2 Contacts On The Right And White To The Left. Now The Dishwasher Will Not Run. The Indicator Lights Are Lit On The Control Panel So There Is Some Power. Do The Connectors Go On The Posts Differently? Adjustments?
#2 Posted : Friday, October 19, 2007 1:51:37 AM(UTC)
Turn power off and verify both switches show continuity when door is closed. If ok you may have jarred loose a wire some place.
