clabrad
#1 Posted : Saturday, December 27, 2008 6:36:24 PM(UTC)
clabrad
Our gas oven does not stay lit. If you unplug the oven, let set for 10 seconds, plug it back it in, set the clock, push either bake or broil, the fan starts, the igniter clicks, flame starts, it burns for 7 seconds and then goes out. It will not repeat that sequence, unless you unplug the oven and start over.the oven light is on continously. it can not be turned off. We have replaced the control panel and membrane switch. That solved some of the problems but the oven and broiler do not remain lit. the burners work fine.
What are the options to repair this oven?
Thank you for your help,
Claude:confused:
Tappan Gas Oven Issues PLEASE HELP! (Oven Repair (including Ranges and Cooktops))
by CMANN1 8/28/2014 6:08:58 PM(UTC)
