jeerlinger
#1 Posted : Sunday, March 6, 2011 2:00:48 PM(UTC)
jeerlinger
Washer overfills when on the highest (super) level. We watched it by taking off the front panel and running a load. Also the air pressure dome has a lot of mold inside and seems to need a cleaning. The water overflows through a plastic tube down into the floor of the machine.
Maybe the air dome needs to be cleaned out?
applianceman
#2 Posted : Monday, March 7, 2011 8:42:49 AM(UTC)
applianceman
Look in the pressure tube to see if it is clogged and if so clean it out and it should be fixed. Also make sure the nipple that the tub connects to isn’t clogged.
Watch the washer during spin and if the spin basket spins during wash then the brakes are bad and the transmission will have to be replaced.
If the tube isn’t clogged and the spin doesn’t turn in wash then you either have a bad water valve or a bad pressure switch. When the washer is running water turn the washer off repeatedly to see if the water stops each time. If the water continues to run when you turn the washer off then the water valve is bad and if the water stops each time the water pressure switch is bad.
[FONT='Times New Roman']One more thing, if the washer has too much suds then water will come out of that overflow tube. When the washer is leaking look in the washer to see if there is an excessive amount of suds. If so either cut down on the amount of detergent or change detergent brands.[/FONT]
Washer Repair Guide
Older Kenmore Washer leak (Washer Repair)
by Guest 2/1/2024 9:56:27 AM(UTC)
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
Washer leak Frigidaire Affinity (Washer Repair)
by Guest 10/23/2023 1:59:44 PM(UTC)
Washer leaks at end of cycle only (Washer Repair)
by Orvilejulius 8/13/2023 8:42:38 PM(UTC)
Kenmore Elite 665.13929K015 Dishwasher Leak (Dishwasher Repair)
by JROTN 12/22/2022 5:12:45 PM(UTC)
Dishwasher Leaking Kitchenaid KDTE334DSS0 (Dishwasher Repair)
by Bscott46 10/4/2022 5:16:08 PM(UTC)
Old Maytag 712 Washer Leaking at Injector Valve (Washer Repair)
by ronp99 9/11/2022 1:40:40 PM(UTC)
Maytag dishwasher leak from bottom of door (Dishwasher Repair)
by Guest 7/27/2022 1:58:00 PM(UTC)
Dishwasher leaks after inlet valve (Dishwasher Repair)
by amazingAZ 6/2/2022 8:57:54 PM(UTC)
LG WM3570HWA Washer Leak (Washer Repair)
by Guest 4/4/2022 12:38:34 PM(UTC)
Maytag top load washer leaking oil from transmission (Washer Repair)
by Rdchapman2 2/27/2022 1:15:02 PM(UTC)
Maytag dishwasher leaking and smoking (Dishwasher Repair)
by Guest 10/19/2021 2:58:51 PM(UTC)
LG Dishwasher Leaking When First Turned On (Dishwasher Repair)
by artriumph 4/22/2021 1:13:56 PM(UTC)
dishwasher leak varies (Dishwasher Repair)
by scottsasa 1/3/2021 4:23:28 AM(UTC)
Delayed dishwasher leak (Dishwasher Repair)
by budflanksteak 12/11/2020 5:03:57 AM(UTC)
