Washer overfills when on the highest (super) level. We watched it by taking off the front panel and running a load. Also the air pressure dome has a lot of mold inside and seems to need a cleaning. The water overflows through a plastic tube down into the floor of the machine.
Maybe the air dome needs to be cleaned out?
Look in the pressure tube to see if it is clogged and if so clean it out and it should be fixed. Also make sure the nipple that the tub connects to isn’t clogged. Watch the washer during spin and if the spin basket spins during wash then the brakes are bad and the transmission will have to be replaced. If the tube isn’t clogged and the spin doesn’t turn in wash then you either have a bad water valve or a bad pressure switch. When the washer is running water turn the washer off repeatedly to see if the water stops each time. If the water continues to run when you turn the washer off then the water valve is bad and if the water stops each time the water pressure switch is bad. [FONT='Times New Roman'] One more thing, if the washer has too much suds then water will come out of that overflow tube. When the washer is leaking look in the washer to see if there is an excessive amount of suds. If so either cut down on the amount of detergent or change detergent brands.[/FONT] Washer Repair Guide
