BaerHouse
#1 Posted : Thursday, February 17, 2011 9:45:48 PM(UTC)
BaerHouse
I have a Thin Twin and the dryer operates but does not have heat. It is a gas dryer & operates on 120V.
Breaker is OK, 120V measured at dryer. Unplugged power, and checked
areas as advised in previous posts.
(40) High Limit Dryer Thermostat is OK
(42) Dryer cycling thermostat is OK
(50) Cut-off tml is OK
What can I check next? and how do I check it?
(this is the first time I have used a multi-meter tester, but am pretty sure
I used this digital one correctly .....registered small numbers for each of the thermostats-with one side of the wires disconnected as instructed in other posts).
thanks for any assistance!
Whirlpool dryer does not heat on medium setting (Dryer Repair)
by redcagle 7/28/2011 10:55:43 AM(UTC)
Whirlpool dryer does not heat (Dryer Repair)
by jkaffel 5/19/2011 2:34:34 PM(UTC)
whirlpool dryer does not heat (Dryer Repair)
by gem190 4/12/2010 6:01:38 PM(UTC)
