Replacement parts for KENMORE 11062062101 | AppliancePartsPros.comSee the attachment for the wiring diagram
[COLOR="DarkRed"]What parts may I need to repair this?[/COLOR]
Cannot say as you will have to do some troubleshooting.
The first thing to check is the power.
The motor etc uses 120 volts while the heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!! [/COLOR]
Next would be the heating coil, the hi-limit thermostat and the thermal cut-off.
If the thermal cut-off is blown, get back to us as there are other things that should be checked before replacing it.
If all OK then check the thermistor.
