BTD2011
#1 Posted : Saturday, February 12, 2011 6:25:22 PM(UTC)
BTD2011
After using the self clean cycle, the oven will not heat in bake, broil or another self clean cycle. There are no errors on the display. The oven acts as though nothing is wrong. I have a parts list, but am unsure of which part is at fault or what parts to test. :confused:
Please post advice. Thanks!
Updated - after posting this I found another thread which mentions the Thermostst (TOD) (item #37 in the parts list) as the most likely part at fault. I will try replacing that part first. Thanks!
Update 2-15-2011, I replaced the TOD and it now works fine!
Oven does not heat to temperature set (Oven Repair (including Ranges and Cooktops))
by lauract 11/13/2015 12:53:01 PM(UTC)
Oven does not heat up (Oven Repair (including Ranges and Cooktops))
by drpflyers 7/21/2015 1:32:17 PM(UTC)
Oven does not heat past 270 (Oven Repair (including Ranges and Cooktops))
by frostyj50 11/18/2013 6:59:17 PM(UTC)
oven does not heat but stove works control panel works (Oven Repair (including Ranges and Cooktops))
by asfimag 11/10/2012 7:02:45 AM(UTC)
GE True Temp Electric Oven does not heat (Oven Repair (including Ranges and Cooktops))
by ksdavis1121 10/4/2012 11:43:04 AM(UTC)
Frigidaire oven does not heat (Oven Repair (including Ranges and Cooktops))
by camliv 9/30/2012 6:40:11 PM(UTC)
by camliv 9/30/2012 6:35:43 PM(UTC)
by escobedo55 3/11/2012 5:08:15 PM(UTC)
Oven does not heat / elements not working (Oven Repair (including Ranges and Cooktops))
by Steve Dyr59 3/8/2012 3:20:24 AM(UTC)
by davepechkis 12/6/2011 6:50:08 PM(UTC)
by fred08 9/2/2011 3:10:27 AM(UTC)
by smedleybr 7/14/2011 12:01:02 PM(UTC)
by tunnelwise 6/14/2011 12:41:11 PM(UTC)
oven does not heat to correct temp (Oven Repair (including Ranges and Cooktops))
by wawpooh 3/8/2011 11:54:18 AM(UTC)
oven does not heat up (Oven Repair (including Ranges and Cooktops))
by candyburch 2/4/2011 2:33:48 PM(UTC)
