dturk
#1 Posted : Thursday, February 10, 2011 10:35:37 AM(UTC)
dturk
Our washing machine is leaking water on the floor. It seems to be coming from the center of the machine. Do you have any suggestions, manuals, or tech sheets? Any help would be greatly appreciated.
magician59
#2 Posted : Thursday, February 10, 2011 10:42:08 AM(UTC)
magician59
Check the pump. Here's a video that will elp you access it.
YouTube - WHIRLPOOL WASHER REPAIR VIDEO 1
dturk
#3 Posted : Thursday, February 10, 2011 11:14:09 AM(UTC)
dturk
Would you have any parts lists or manuals?
magician59
#4 Posted : Thursday, February 10, 2011 1:40:29 PM(UTC)
magician59
dturk
#5 Posted : Monday, February 14, 2011 7:08:07 AM(UTC)
dturk
Okay, after breaking down the diagram, we found there is a 1-1/2" crack in the outer drum. Do you know if we can epoxy this, or do we have to purchase a new drum?
magician59
#6 Posted : Monday, February 14, 2011 9:27:13 AM(UTC)
magician59
I would try to epoxy the tub first. You can replace it, but if the epoxy holds, it may buy you some time.
dturk
#7 Posted : Monday, February 14, 2011 10:20:35 AM(UTC)
dturk
Thanks, I appreciate all your help! Especially because the machine is only 3 years old. I can't imagine how the tub got a crack in it. ???
magician59
#8 Posted : Monday, February 14, 2011 10:30:13 AM(UTC)
magician59
If you have the original paperwork, you may want to check to see if the tub is still under warranty.
dturk
#9 Posted : Monday, February 14, 2011 11:47:52 AM(UTC)
dturk
Just called Whirlpool. they said it was only covered for 1 year. Don't understand how that can break. Never buying Whirlpool again!
dturk
#10 Posted : Thursday, February 17, 2011 4:43:10 AM(UTC)
dturk
We were able to exposy the outer drum and have run several loads through with no leaks. We will keep a close eye on it. Now, it seems like the clothes are more wet after the spin cycle. Did we re-assemble something wrong?
Amana washing machine leaking (Washer Repair)
by strombley46 8/31/2013 1:23:28 PM(UTC)
Washing machine leaking 1 month after replacing tub and bearing seal (Washer Repair)
by brian mitchell 2/19/2010 6:29:11 AM(UTC)
Kenmore Washing Machine Leaking (Washer Repair)
by mkcastrom 8/7/2009 5:27:30 PM(UTC)
2008 Crosley Washing Machine Leaking (Washer Repair)
by ladybug55552001 1/24/2009 11:33:21 AM(UTC)
Maytag Washing Machine Leaking from the back (Washer Repair)
by kdollva 8/27/2008 8:07:21 PM(UTC)
Kenmore washing machine leaking near the front (Washer Repair)
by ron1daddy 8/14/2008 6:34:08 PM(UTC)
Washing Machine leaking - spin basket out of balance? (Washer Repair)
by sherryh 3/30/2008 3:31:34 PM(UTC)
by sherryh 3/30/2008 2:43:10 PM(UTC)
roper washing machine leaking red oil (Washer Repair)
by bandksdad 11/21/2007 5:48:40 AM(UTC)
