volsunc
#1 Posted : Monday, January 31, 2011 10:57:15 AM(UTC)
volsunc
My fridge and freezer has all of a sudden stopped cooling. The fan on the bottom is turning . Have no clue what to do or check. any info would be much appreciative.
volsunc
#2 Posted : Monday, January 31, 2011 1:44:22 PM(UTC)
volsunc
The compressor is working and found alot of frost on the freezer side. Cleared off all the frost and still is not cooling.
#3 Posted : Tuesday, February 1, 2011 1:43:59 AM(UTC)
Is your freezer fan working?
volsunc
#4 Posted : Tuesday, February 1, 2011 3:36:37 AM(UTC)
volsunc
yes the freezer fan is working
#5 Posted : Tuesday, February 1, 2011 5:17:42 AM(UTC)
The damper motors on these are very reliable. I would jam the damper door almost 1/2 way open. If your temperatures now become "normal" you most probably have either bad ff thermistors, or a bad motherboard. All the thermistors measure around 5K ohm at room temperature, if you have a meter, just check.
volsunc
#6 Posted : Tuesday, February 1, 2011 5:43:14 AM(UTC)
volsunc
I have just found my heater tube in the freezer is blown( black). would that have anything to do with my problem?
#7 Posted : Tuesday, February 1, 2011 2:43:00 PM(UTC)
You said before there still was no cooling after you removed the frost. If defrost is not working at all, you would still get good performance for a few days till it frosts over again.
fridge and freezer not cold.enough (Refrigerator & Freezer Repair)
by bdogm 7/10/2014 9:15:21 AM(UTC)
Fridge and freezer not cold enough (Refrigerator & Freezer Repair)
by Peepdisshiznit 9/14/2011 3:39:54 PM(UTC)
Amana fridge and freezer not cold (Refrigerator & Freezer Repair)
by heyheyyouyou 7/7/2010 9:47:10 AM(UTC)
help fridge and freezer not cold at all fridge went first then the freezer did (Refrigerator & Freezer Repair)
by jeannie beck 2/20/2010 8:56:53 AM(UTC)
Fridge and Freezer not cold enough (Refrigerator & Freezer Repair)
by PaulBrown 11/15/2009 1:55:09 PM(UTC)
Fridge and Freezer not cold (Refrigerator & Freezer Repair)
by Handychick 11/13/2009 9:31:29 AM(UTC)
GE fridge and freezer not cold (Refrigerator & Freezer Repair)
by sabaron 8/11/2008 6:32:01 PM(UTC)
