I have determined that the adaptive defrost board is not functioning. The new board that I purchased at Appliance Pros is not an exact replacement. There are six pins on the board that compliment the old board except for pin #5. The old board pin #5 is marked test and the new board is marked door. There is no connection to terminial #5 and it is temperairly jumpered to #6 for test defrost purposes. Pin Old Board New Board #1 Defrost Heater Defrost Heater #2 Compresor Compressor #3 L2 L2 Skip pin #4 Stat Stat #5 Test Door #6 L1 L1 My Question is do I loose the test function with the new board and do I need to jumper pin #5 permanently as there is no door function wired to pin #5 on my unit?
