runavy
#1 Posted : Sunday, November 30, 2008 5:47:09 PM(UTC)
runavy
I have a Jenn-Air model SVE47500 oven with membrane touch pads on the control panel. The Cancel/Off touchpad began working intermittently a couple weeks ago and has now stopped working altogether. The other touchpads work fine. I have opened up the control panel and see a ribbon cable connecting the motherboard to something inaccessible inside the panel, which I assume is the back side of the touchpads. To repair this, do I have to:
1. replace the motherboard (appears simple)
2. replace the ribbon cable (not sure how to do this since the inside of the control panel appears inaccessible)
3. repair/replace the Cancel/Off touchpad (not sure how to do this either)
4. replace the entire control panel
Thanks for the advice before I have to resort to calling a repair person.
Cory Culver
#2 Posted : Sunday, November 30, 2008 6:33:08 PM(UTC)
Here is your parts breakdown
Model Search
And here is a service manual
http://www.servicematters.com/m...ibrary/docs/16010191.pdf
Look at Page 1-16. You can then check to be sure it is the membrane switch that is bad using a meter.
The switches are not repairable so you will have to replace the panel Item 2 in the Control panel section
Jenn air Control Panel issue (Oven Repair (including Ranges and Cooktops))
by CShort5 2/13/2010 4:58:02 AM(UTC)
