rlrjnr2
#1 Posted : Monday, January 10, 2011 12:10:09 PM(UTC)
rlrjnr2
My quietpower 3 also is not draining completely. It is not a vent problem with my homes drain system. It seems the pump is not staying on for anough time to complete the draining process. Could the sensor turbitity be malfunctioning at the back of the sump?
Thank you for responding!!
rlrjnr2
#2 Posted : Monday, January 10, 2011 12:47:27 PM(UTC)
rlrjnr2
What tells this model how long to run drain pump?
#3 Posted : Monday, January 10, 2011 3:25:27 PM(UTC)
There are two flapper valves on both ends of the drain pump (#328 on the diagram).
Remove the dishwasher from the cabinet and check both of them.
- The flapper valve Part number: AP3419048
rlrjnr2
#4 Posted : Monday, January 10, 2011 9:07:11 PM(UTC)
rlrjnr2
Sure as heck I took out the pump and checked both ends and the end at the sump was blocked by debris and wasn't opening fully! Also found out the draining is a timed event on this model.
Thanks Gene.
#5 Posted : Tuesday, January 11, 2011 12:25:57 PM(UTC)
You are welcome. I'm glad you were able to fix it.
Kitchenaid KDTE104ESS1 not completely draining or drying (Dishwasher Repair)
by BigDan37 5/16/2019 8:18:47 PM(UTC)
Whirlpool Quiet Partner IV not completely draining (Dishwasher Repair)
by mixster 9/7/2013 8:46:33 AM(UTC)
Washer not completely draining or spinning on medium to heavy leads (Washer Repair)
by IndyBolden 2/5/2013 5:26:12 AM(UTC)
Washer not completely draining (Washer Repair)
by stthomas11 4/28/2012 5:51:02 AM(UTC)
dishwasher not completely draining (Dishwasher Repair)
by mim 12/1/2010 9:42:17 AM(UTC)
Not completely draining (Dishwasher Repair)
by jsvango 11/6/2009 4:55:31 AM(UTC)
