#1 Posted : Saturday, December 11, 2010 4:12:00 PM(UTC)
Remove the front bottom access panel.
Check the thermal fuse (#59 on the diagram) for continuity. If it is open, replace it together with the cycling thermostat (#42). Make sure the dryer exhaust line is clean all the way through the outlet. Most of the time it needs a professional cleaning.
- The thermal fuse Part number: AP3133489
- The cycling thermostat Part number: AP2913007
#2 Posted : Saturday, December 11, 2010 7:17:55 PM(UTC)
I don't think there is anything else involved if the fuse is open.
#3 Posted : Sunday, December 12, 2010 2:30:07 AM(UTC)
[COLOR="Blue"]I verified that there is power.[/COLOR]
Did you check that you not only had 240 but also the two 120 legs.
[COLOR="Blue"]
The drum spins freely.
[/COLOR]Could be it is spinning too freely.
The unit has a belt switch, so perhaps your belt is broken.
