ferny22
#1 Posted : Thursday, December 2, 2010 9:30:45 PM(UTC)
ferny22
I purchased about a year ago, motherboard. After it was installed, it actually did not made a difference. Took it out, placed the old one. Called another person, they replaced motherboard, which it did not do the trick, same as item purchased from you guys. Problem is, water not being supplied, ice maker freezes, and on the food side, it is not cold. Is there any other part I can buy that will work?
magician59
#2 Posted : Friday, December 3, 2010 6:35:28 AM(UTC)
magician59
If the freezer is freezing ice, the temperature is OK in there. Is the Evaporatoe (in the freezer) fan working? Check the damper, and return air vent (if there is one) to make sure there are no obstructions. Also check the door gasket for any obvious gaps or tears that could allow warm air to leak in.
Let us know what you observe, and we'll go from there.
