When I turn the dial to select the wash cycle the selections don't light up. After turning the dial several times slowly only one wash cycle will light up. If you try to change anyghting the lights go off. 70% of the time if you start the wash cycle it will go. I have replaced the door swith and the control board. After I replaced the control board it worked for about 2 weeks then this problem started. My guess is the control board is defective?
