I have frigidair elec stove fef455bbc when in use laud pop was heard. main oven stopped working. timer still lit. checked continuity of both heating elements showed continuity. checked temp sensor it was good 1000 ohms is it the controller? even though still lit? what is part No. parts show a clock/timer? on latch motor I showed continuity between copper wire and bk/w wire. please help
