icemaker not making ice. Refridgerator just serviced by a@e. parts replaced include compressor/dryer. evaprator and heating coil. This repair took 3 weeks. After a@e done freezer and fridge cool well but icemaker inop. Before repair icemaker worked normally. Ice maker part # 106 62 6667. L-N pwr ok 110v, Jumper T-H motor runs and icemaker goes thru cycle. no water added. n-v as motor cycles I read 110v for about 7s as icemaker asks for water. It looks like water valve is on the bottom of fridge next to water filter.. not an easy place to get to wires and check . Does this sound like a water valve problem... inbound water lines do not look kinked and in back of ice maker heated lines to see if frozen .. no help. if i manually fill ice maker with water ice cubes are made and ejected normally. Any good ideas, and what is part number of water valve Thanks
