First my GE fridge needed a new main board and now my GE oven wont work. Both less than 5 years old. Wont be buying GE again :mad:
Here is my prob. The GE oven top gas burners work fine, no prob. But the oven and broiler wont light. I have read that I prob need to replace the igniters, but are there 1 or 2 igniters in the oven area? Is there one for the broiler and one for the oven? If there are 2 and both stopped working at the exact same time, does that not lead to a different problem?
I know nothing about appliace repair so any help would be MUCH appreciated :)
Thanks Patrick
I did some more testing and the brolier igniter glows and DOES light! And if there is an igniter in the lower part of the oven, that is not glowing at all and wont light. I do not smell any gas. What would next step be? To change the lower igniter in the oven?
Thanks again
