svgsmom
#1 Posted : Wednesday, October 29, 2008 3:11:45 PM(UTC)
svgsmom
Washing machine won't drain. We have removed the drainage pipe in the rear several times to check for a blockage, but the drain is clear. Is there another location where the machine can be blocked?
misterfixall
#2 Posted : Thursday, October 30, 2008 2:45:31 PM(UTC)
misterfixall
have you checked the drain hose under sink , stick a screw driver down where hose connects to .other than that it could be a pump issue , remove front door panel +bottom panel ,has torque screws to easier acess to pump
