Our Frigidaire oven has always maintained temperature very well.
Recently it started dropping 5 degrees from what the reading was on the clock/temperature setting. Suddenly it is now approximately 15 to 20 degrees below the reading setting and I am unable to heat the oven past 350 degrees.
Where would you recommend I begin to troubleshoot this problem?
Any help is much appreciated.
THIS FORUM IS DEAD!!!!!!! |
