I have the Maytag MGR6775ADB/Q/S/W. In order to change the ignitor, do I need to pull the oven out and access the connection from the back? The bake ignitor in the upper oven needs replacing. Thanks
You don't need to pull the range out to replace the igniter; but you DO need to turn of the power to the appliance. Pulling it away from the wall will keep you from having to go to the breaker box, will make the replacement a little easier, and will give you an opportunity to clean an area that seldom gets our attention.
