Jenn-AIR Oven LED light not working
The LED display light (shows temp., time and timer time) is not working but the oven is heating perfectly. What part number do we need to order to replace the LED??? Is this difficult to replace???
Please advise.
Hi Patty,
The solution is to replace the Electronic Oven Control (EOC). This part is not too difficult to replace yourself.
To remove the control panel, open the oven door as wide as possible. Remove the three screws from the top of the control panel and the three screws at the bottom of the control panel. Grasp the control panel by placing hands on the right and the left sides of the panel, pull out and down to disengage.
