Hello, I don't have much doubt that the oven control panel is the diseased part, can't read oven settings, surface light remains on all the time, hot or cold. My question is, this stove is built in and will not be easy to remove, I need to know how to get to the control pad before I purchase a new one. does it involve pulling the stove out or can I access it through some other means? Thank You in advance.:confused:
Wanted to take the time to say thank you Gene, guess the $300 pad is cheaper than a replacement stove, it will be a job to get out of the counter the way it was installed but either way looks as if it has to come out. Thank You again, doubtful:)
You are welcome. I'm glad it helped you. Good luck.
