ashtongt
#1 Posted : Monday, August 30, 2010 12:19:07 PM(UTC)
ashtongt
Help!! Dryer started taking along time to dry , this went on for about a month and then one day we smelled the smell that you smell when you first turn your electric heaters on after summer and now it will run but won't heat, both breakers are fine, what do we check now?
Joe / APP Team
#2 Posted : Monday, August 30, 2010 12:44:57 PM(UTC)
Joe / APP Team
Ashton,
The first thing to check is, you exhaust venting and vent hood for clogs,kinks, and the hood for damage.
then you need to check the hi limit thermostat, thermal fuse, and heater element for closed circuits with a meter.
Also check the wiring to those components for damage.
I've attached the service manual instructions for accessing the heater and thermostats and fuse.
(see below)
1. Unplug dryer or disconnect power.
2. Remove the rear panel.
3. To remove the thermal cutoff (TCO)
a) Remove the two wires from the TCO
terminals.
b) Remove the hex-head screw, unhook
the end of the bracket, and remove
the TCO.
4. To remove the heater and inlet thermistor/
high-limit thermostat
a) Lift the locking tab and remove the
2-wire connector from the inlet thermistor.
b) Remove the wire connector from the
high-limit thermostat terminal.
c) Remove the two wire connectors from
the heater terminal block.
d) Remove the two hex-head screws from
the heater assembly and remove the
assembly
e) Using a flat-blade screwdriver, pry the
inlet thermistor terminal off the heater
terminal, and remove the thermistor from
the assembly.
Good Luck,
Maytag Bravo Dryer (Dryer Repair)
by Rhart 5/16/2019 5:05:42 AM(UTC)
