retzy
#1 Posted : Monday, August 30, 2010 10:22:02 AM(UTC)
retzy
when drum is turning it has a very loud squeal. Do I need to only replace the bearing?
#2 Posted : Tuesday, August 31, 2010 1:03:59 AM(UTC)
Replacement parts for FRIGIDAIRE FEZ831AS1 Lc - Frigidaire | AppliancePartsPros.com
[COLOR="Blue"]Do I need to only replace the bearing?[/COLOR]
Yes that is the most common problem with this type of drum mounting.
Could be it just needs cleaning and re-lubing with high temperature grease.
Also when removing the rear cover (Item 6 in Section 1) be careful as the ball bearing (Item 5 in Section 1) likes to take off and hide once it is released.
Other possibilities would be the front glides or the idler wheel
