edwardann
#1 Posted : Saturday, August 28, 2010 9:32:40 AM(UTC)
edwardann
i NEED TO INSTALL A THERMAL LIMITER IN MY DRYER, BUT i CANNOT OPEN THE CABINET.
sidfink43
#2 Posted : Monday, August 30, 2010 4:58:15 PM(UTC)
sidfink43
On these models insert a screw driver carefully in the gap between the top and front and release clips and pry up the top which will open up on hinges. This will give you access to remove the front, and take off the back service panel to get to the pulley to release the belt if you need to.
