warzdad
#1 Posted : Friday, August 27, 2010 9:07:43 AM(UTC)
warzdad
OK Denman I'm on it once again. Here come da meterman.
Update to above 8/27 11:48 AM:
Traced back to Heater Relay (306199). bypassing HR wires #9 BLK and #3 BRN yeilds 120 VAC.
Can you tell me how to check it properly to be sure this is the culprit?
warzdad
Read more: http://forum.appliancepartspros...post263596#ixzz0xpKpjrVD
http://forum.appliancepartspros.com
Joe / APP Team
#2 Posted : Friday, August 27, 2010 1:22:27 PM(UTC)
Joe / APP Team
warzdad
Warzdad,
You also need to check for the low voltage to the heater relay from the control board :
Basically the 2 small (3/8")terminals are the DC volts from the control board.
Red #27 and BLK/BRN #30 you should read 24 VDC across the wires when you select any heated dry cycle and start the dryer.
If you have the 24 VDC there,and 120 VAC on the Blk wire #9, but the unit has no heat, you've got a bad relay,open hi limit thermostat, open heater element.
No 24 VDC indicates a broken wire or bad control board.
No 120 VAC indicates no L1 from the outlet/power cord.
Hope this helps,
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
Samsung Dryer no heat (Dryer Repair)
by Guest 10/5/2021 5:41:36 PM(UTC)
LG gas dryer no heat (Dryer Repair)
by Guest 8/15/2021 10:28:45 AM(UTC)
Kenmore model 11060022010 electric dryer no heat (Dryer Repair)
by mike5466 5/1/2020 10:29:22 AM(UTC)
Samsung dryer no heat - 5 possible components? (Dryer Repair)
by sgsiegel 2/11/2018 7:02:33 AM(UTC)
by tombeird 11/8/2017 2:32:42 PM(UTC)
Maytag Atlantic Dryer no heat but everything tests ok (Dryer Repair)
by oldebrowndog 11/10/2015 11:38:46 AM(UTC)
Dryer No Heat.mind boggling! (Dryer Repair)
by andrelaplume 10/10/2015 7:22:06 PM(UTC)
by fhorta 9/28/2015 12:22:36 PM(UTC)
Whirlpool gas dryer no heat (Dryer Repair)
by alabamainnevada@yahoo.com 6/23/2015 5:54:15 PM(UTC)
hot point dryer no heat and timer doesn't advance (Dryer Repair)
by gooseofdeuce 4/18/2015 8:29:56 AM(UTC)
by SEMIFAST0 3/15/2015 9:00:11 AM(UTC)
Gas Dryer NO HEAT/FLAME and possible bad timer? (Dryer Repair)
by noles9399 2/26/2015 10:12:14 PM(UTC)
roper dryer no heat (Dryer Repair)
by chuck vaughn 12/1/2014 1:35:50 PM(UTC)
maytag gas dryer no heat (Dryer Repair)
by steve5024 11/8/2014 8:57:28 AM(UTC)
