GE electric clothes dryer starts when you turn the momentary start switch but when you let go it stops. You can hold the switch on and it will run. This would indicate a bad run coil in the motor? Can the run coil be purchased seperately from the entire motor?
Here are your parts Replacement parts for General Electric DWSR485EA1WW Electric dryer | AppliancePartsPros.comI cannot get a wiring diagram for this unit as GE likes to keep everything a secret. [COLOR="Blue"]This would indicate a bad run coil in the motor?[/COLOR] I do not think it would be a blown run winding as I doubt the motor would go on just the start winding. [COLOR="Blue"]Can the run coil be purchased seperately from the entire motor?[/COLOR] No Usually one of the centrifugal switches on the motor is wired in parallel with the start switch to hold the motor on when you release the start switch. It also removes the start winding from the circuit. Perhaps this is shot. If it is you will have to replace the motor. If you do not have heat when you hold the push to start, it may be that the mechanism that closes the switches is clogged up with lint etc. and is not working. The second centrifugal switch on the motor is for the heating coil. From the parts I see that your idler wheel assembly has a switch sometimes this is wired in series with the run winding so perhaps it is shot or is not being activated for some reason. If you do not have the wiring diagram look inside the unit's control console often they put one in there. Here is a link. See Item 28 it has a couple example wiring diagrams for GE's. http://www.applianceaid.com/ge-dryers.html |
THIS FORUM IS DEAD!!!!!!! |
