hoss1923
#1 Posted : Tuesday, August 24, 2010 7:44:52 AM(UTC)
hoss1923
I am giving service to a Whirlpool Gas Dryer model # WGD8300SW0. It had a bad flame eye, igniter, and high temp limit. I replaved all of the bad parts, now the only problem I have is that the heat relay is not pulling in. I believe it is a bad timer contact, but I cannot find an electrical diagram to know how to check it. I know I check the contact between the black and blue wire but mine has one black and the rest are blue. Thanks
Joe / APP Team
#2 Posted : Tuesday, August 24, 2010 9:01:48 AM(UTC)
Joe / APP Team
I'm not clear about the wire colors or location of the wires you are discussing.
Did you also check the thermal cut out and thermal fuse for closed circuits ?
Did you check the thermistor for 10,000 ohms resistance (at room temperature) ?
(can also check at the main control board at connector P14 pin 3 to pin 6 in the harness).
If not, you need to check those as well.
Based on your description there are several more components you need to check, these checks should be made at the main control board :
These are live voltage checks(120 VAC) so be careful...
With the machine plugged into the outlet,
From chassis ground to conn. P9 pin 2 (L1/ black) you should read 120 VAC.
At the heater relay NO conn.(black) to chassis groud will be 120 VAC.
Program a timed dry with high heat setting.
You should read 120 VAC from COM(red) to chassis ground(voltage out to gas valve).
No voltage out on red COM terminal at heater relay, would indicate a bad main control board, if all other checks are proper.
Good Luck,
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
Whirlpool Gas Dryer motor overheating - shuts-off (Dryer Repair)
by animateme 9/19/2019 11:59:22 AM(UTC)
Whirlpool gas dryer (Dryer Repair)
by JoAnninWV 5/7/2017 8:06:39 PM(UTC)
Whirlpool Gas Dryer heating intermittently, timer not working (Dryer Repair)
by christyhecht 5/2/2017 10:50:15 AM(UTC)
Whirlpool Gas Dryer screaching noise at first, then stops mid cycle (Dryer Repair)
by SRALPH 12/14/2016 11:40:34 AM(UTC)
Whirlpool Gas Dryer Takes Too Long (Dryer Repair)
by bijalshah01 9/28/2016 5:28:12 PM(UTC)
Whirlpool Gas Dryer Heating Problem (Dryer Repair)
by rinkugaya 9/24/2016 3:17:35 PM(UTC)
Whirlpool gas dryer heating issues/gas smell (Dryer Repair)
by Houseforsaken 8/8/2016 1:24:58 PM(UTC)
Whirlpool gas dryer no heat (Dryer Repair)
by alabamainnevada@yahoo.com 6/23/2015 5:54:15 PM(UTC)
Need Wiring Diagram for Whirlpool Gas Dryer (Dryer Repair)
by ToddErickson 2/2/2015 4:11:08 PM(UTC)
Whirlpool gas dryer only heats for the first 5-10 minutes of cycle (Dryer Repair)
by Peter Wood 9/18/2014 7:28:53 PM(UTC)
Whirlpool Gas Dryer LP to NG (Dryer Repair)
by kyle_8888 4/10/2014 9:49:37 AM(UTC)
Whirlpool Gas Dryer - heat won't stay on (Dryer Repair)
by tubegeek 3/11/2014 1:10:32 PM(UTC)
by jeswon 12/16/2013 6:55:50 AM(UTC)
by miller42 9/4/2013 6:43:14 AM(UTC)
