The moisture assembly (AP2107715) came off of the door assembly. the assembly holds the lint filter. when this shappened the two red wires came off. the assembly has what looks like two chrome bars with spade connectors on each end. How do I determine which spade to put the connectors on??? I have two wires and four possible places to put them.
thank you Ward
Here is the wiring diagram http://manuals.frigidaire.com/prodinfo_pdf/Webster/134064800e.pdfIt does not matter which end of the strips the wires attach to as long as you have one wire going to each strip. The way it works is that the board monitors the resistance between the strips. When totally dry the resistance is infinite (open). When there is moisture between the strips there is a resistance, the board senses this and continues drying the clothes. |
THIS FORUM IS DEAD!!!!!!! |
Great, thanks for the help and the theory behind it.
