AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer Help: Dryer works fine and turns on fine but will stop heating after 1min
Hello., I have a Frigidaire Electric Dryer Model GLEQ2152ES. My dryer had a bad bearing and heating coil so I replace it about 6 months ago. It was working perfect up untill a week ago when my cloth wasnt drying. I went ahead and took a look at it and it seems to work fine for the first 2 minutes of use and then the heating coiling doesn't heat anymore after those 2 minutes.. Just blows air. Anyone have a idea on what the problem might be? Thanks
Another thing, I switch the settings to Towels and it was heating really bad. The heating coils didnt want to stop heating. It ran like this for 4 minutes untill I had to stop it due to it was getting extremely hot.
Forgot to add
Sometimes the dryer will heat up extremely HOT, then sometimes it will not heat up at all. The drum spins perfectly and no weird sounds. My guess is that it needs a new Thermistor?
Dryer Repair
