Dryer started out with problems by stopping mid cycle, but leaving front panel still lit up where it left off. I could restart that machine and everything would be fine and the load would finish. Had a power surge in the house and dryer was running. It stopped, only this time when I tried to restart it, it would light up correctly on the front panel, but when I pushed the button to start it would make a click but nothing would happen. Continued to dink with it and problem got worse. Finally got to the point that it would only stop if I opened the door. I could push the off button and all the lights would go off, but the dryer would not stop running. Repairman came out and said it was the control board. I ordered one and replaced it. Now when I do diagnostics, I get an E3 error. All of the buttons light up on the front panel, but when I rotate the main dial for cycle type selection, it beeps extremely loudly and various lights go on and off on all parts of the front panel. Is it possible that the power surge effected both the control electronics and the machine control board?
Originally Posted by: gastover  Dryer started out with problems by stopping mid cycle, but leaving front panel still lit up where it left off. I could restart that machine and everything would be fine and the load would finish. Had a power surge in the house and dryer was running. It stopped, only this time when I tried to restart it, it would light up correctly on the front panel, but when I pushed the button to start it would make a click but nothing would happen. Continued to dink with it and problem got worse. Finally got to the point that it would only stop if I opened the door. I could push the off button and all the lights would go off, but the dryer would not stop running. Repairman came out and said it was the control board. I ordered one and replaced it. Now when I do diagnostics, I get an E3 error. All of the buttons light up on the front panel, but when I rotate the main dial for cycle type selection, it beeps extremely loudly and various lights go on and off on all parts of the front panel. Is it possible that the power surge effected both the control electronics and the machine control board? Gastover, Which part did you install ? And are you sure you installed it properly. I would not be surprised, if you need both parts, after a voltage spike. Based on your description you should or do need the control panel board. Part number: AP3775978
