duvanderz
#1 Posted : Wednesday, August 18, 2010 4:03:39 AM(UTC)
duvanderz
I'd like to check if the belt is OK on the dryer but I'm not sure how to get to it. Do I need to take just the front panel off or the top first and then the front.
Thanks,
Vince
sidfink43
#2 Posted : Friday, August 20, 2010 10:25:30 AM(UTC)
sidfink43
If you take out the two screws under the lint filter top you can insert a screw driver in the gap between the top and front near the edges and release the top which will pivot up. You can now inspect the belt.
If you need to change the belt you can now remove the front by disconnecting the door switch and take out the two screws that hold it to the cabinet. Lift it up and out of the clips that hold it on at the bottom.
Kelvinator Washer belt replacement? (Washer Repair)
by Eric Kelsheimer 8/24/2007 9:05:45 AM(UTC)
