missyk35986
#1 Posted : Tuesday, August 17, 2010 9:49:09 AM(UTC)
missyk35986
How do you replace heating element?
Joe / APP Team
#2 Posted : Tuesday, August 17, 2010 10:12:40 AM(UTC)
Joe / APP Team
Console Removal
1. Disconnect power supply to unit.
2. Remove Top Cover.
3. Remove two screws mounting the Heater PCB Board
4. Disconnect the black and white connectors.
5. Remove four screws attaching Console to washer
dryer.
5. Remove two screws in the door area.
6. Pull Front Panel forward and disconnect the Interior
Light harness.
7. Lift the Front Panel off the three tabs across the
bottom and remove.
6. Rotate Console down and remove from dryer
Heater Assembly Removal
3. Remove Console.
4. Remove Front Cover.
5. Remove Heater Assembly retaining screw.
6. Slide Heater Assembly out the front of dryer..
7. Remove the wiring terminals from the Heater assembly.
Friidaire Range FRC340M-T1 Control Switch Info Needed (Oven Repair (including Ranges and Cooktops))
by Techowl 9/7/2019 12:52:56 PM(UTC)
Vintage GE Oven information (Oven Repair (including Ranges and Cooktops))
by wiia 4/27/2019 7:23:01 AM(UTC)
thermador LP conversion info needed .... (Oven Repair (including Ranges and Cooktops))
by ertech 11/24/2018 4:21:56 PM(UTC)
Need some info please, (Washer Repair)
by JeremyEPHVACR 1/16/2017 9:46:32 AM(UTC)
info on part (Refrigerator & Freezer Repair)
by richard1936 7/17/2014 1:51:37 PM(UTC)
Dryer will not turn on, need wiring/hookup info (Dryer Repair)
by rsflores9 6/14/2014 3:06:00 PM(UTC)
help/info needed-Mini fridge hear air coming out (Refrigerator & Freezer Repair)
by adam120674 10/27/2013 3:23:15 PM(UTC)
Need info on testing "cycling thermostat" (Dryer Repair)
by 3dDetailer 9/30/2013 6:05:38 AM(UTC)
Roper RTW4640YQ service info? (Washer Repair)
by bcstrong1 3/27/2013 8:18:09 AM(UTC)
Info on Daewoo Washer (Washer Repair)
by marshallfla 3/20/2013 6:53:06 AM(UTC)
GE Cooking Range control panel info (Oven Repair (including Ranges and Cooktops))
by repairgal 9/13/2012 6:29:33 PM(UTC)
Kenmore Coldspot starter info needed (Refrigerator & Freezer Repair)
by texrock 8/14/2012 5:52:20 PM(UTC)
freezer working, frig is not. new info (Refrigerator & Freezer Repair)
by ndfinn 7/6/2012 4:54:27 PM(UTC)
Need Information (Refrigerator & Freezer Repair)
by cdoc 6/27/2012 12:42:18 PM(UTC)
needs information (Dishwasher Repair)
by jitujitu100 3/13/2012 7:26:20 PM(UTC)
