How do you replace heating element?
Originally Posted by: missyk35986  How do you replace heating element? Console Removal
1. Disconnect power supply to unit. 2. Remove Top Cover. 3. Remove two screws mounting the Heater PCB Board 4. Disconnect the black and white connectors. 5. Remove four screws attaching Console to washer
dryer. 5. Remove two screws in the door area. 6. Pull Front Panel forward and disconnect the Interior Light harness. 7. Lift the Front Panel off the three tabs across the bottom and remove. 6. Rotate Console down and remove from dryer
Heater Assembly Removal
1. Disconnect power supply to unit. 2. Remove Top Cover. 3. Remove Console. 4. Remove Front Cover. 5. Remove Heater Assembly retaining screw.
6. Slide Heater Assembly out the front of dryer.. 7. Remove the wiring terminals from the Heater assembly.
