AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Bosch d/w replaced control module, display works, but no water
I had the usual problems with my Bosch d/w--cycles wouldn't end, etc. Replaced the control module today after a lot of wrestling to put the door back on. Flipped the breaker, turned the unit on, the lights lit, the display worked, but I could not hear any water coming into the machine and the cycle wasn't starting even though the display was counting down. I tried to run diagnostics but am not sure I pushed the right combination of keys--got nowhere with that. Can anyone help? This is incredibly frustrating after thinking I had the problem solved after a lot of work. Thanks in advance for any help!
This is the exact problem I am having. Anybody have the answer?
Dishwasher Repair
