THE DRYER STOPS HEATING AFTER THE FIRST IGNITION. I REPLACED THE IGNITOR AND THE FLAME SENSOR. wHAT SHOULD I DO NEXT?
Originally Posted by: fericutz  THE DRYER STOPS HEATING AFTER THE FIRST IGNITION. I REPLACED THE IGNITOR AND THE FLAME SENSOR. wHAT SHOULD I DO NEXT? Well the good thing is you replace some old parts. The bad thing is they were not the right parts. Replace the coils on the gas valve and that will do it. The secondary coil is bad, but the kit comes with both coils. Tom ApplianceEducator.com - Parts
Originally Posted by: kayakcrzy  Well the good thing is you replace some old parts. The bad thing is they were not the right parts. Replace the coils on the gas valve and that will do it. The secondary coil is bad, but the kit comes with both coils. Tom ApplianceEducator.com - Parts Tom : Thanks for your help!!!!! Clothes are drying right now
