Here are your parts, includes a wiring diagram
Replacement parts for cye2000aye models | AppliancePartsPros.comCould not cross reference this part (530771) so do not know what it is.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Next would be to check the heating element and the Safety thermostat for resistance.
