billtti
#1 Posted : Wednesday, August 4, 2010 9:15:04 AM(UTC)
billtti
I have a problem in that I need to know the model number for the GE dryer from 1995, but can not locate it anywhere online. Does anyone have access to that information from their experiences or business?
The unit itself nolonger has any of those markings in the 3 locations.
any help would be greatly greatly appreciated.
#2 Posted : Saturday, August 7, 2010 9:38:11 AM(UTC)
Only thing I can suggest is to unplug the unit, open up the control console and check the number on the timer. Then come back to AppliancePartsPros parts site and use that number to search with a little luck a Model Number may come up.
If more than one model number comes up you will have to compare the parts breakdowns with your unit for a match.
Also, it is possible that a wiring diagram/ tech sheet is stored in the console which may give a model number.
