Don Spangler
#1 Posted : Tuesday, August 3, 2010 1:28:45 PM(UTC)
Don Spangler
Dryer quit heating and the thermal fuse was blown. Replaced fuse, heating element and belt. Dryer ran for one complete cycle and then quit heating on next cycle. I have cleaned all of inner surfaces, blower housing and replaced the outlet hose. I have not remove the fuse to check it yet but wonder what could be causing it to blow?
#2 Posted : Tuesday, August 3, 2010 3:37:02 PM(UTC)
Check the blower wheel and make sure the dryer exhaust line is clean all the way through the vent outlet. Make sure the vent outlet is working properly.
Don Spangler
#3 Posted : Tuesday, August 3, 2010 6:47:14 PM(UTC)
Don Spangler
Vent outlet has been replaced and exhaust line is clean. When running without heat the exhaust is strong enough to open the vent. I did find the tube from the blower outlet to the vent tube wasn't properly seated. It appeared to be that way from the beginning. I question the thermostat on the blower housing. It is a three wire sensor and shows continuity from the blue to orange in both directions but open between the purple and orange and purple and blue. Is there anything else that controls the heat? Thanks, Don.
#4 Posted : Wednesday, August 4, 2010 1:43:08 PM(UTC)
Don,
Here is the Tech sheet.
Here are the breakdown diagrams and Replacement parts for AMANA ALE643RAW Dryer - Ele | AppliancePartsPros.com
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
